in Will's book,,,, he addresses powering a laptop via 12v....he says:
Powering a Laptop without an inverter
Powering a laptop with an inverter is a bit more inefficient than powering it with DC power, directly from your battery. If you use a laptop often, you will want to power it directly from a 12-volt source with a voltage converter. This will take your solar systems 12 volts, and bump it up to 17/19/24 volts, or whatever your laptop requires. The easiest way to do this is to find a laptop charger that can plug into a cigarette lighter. These chargers usually come with a variety of adapters so that they can work with different laptops. Usually, they can output different voltages to work with different laptops. If this works for your needs, you can splice the two power wires into your system, and attach it directly to the fuse block like any other appliance. You can also wire it directly to an XT-60 connector plug so that you can plug it in at different locations of your vehicle (if you have female plugs wired around your vehicle).
If you want to complicate things, you can buy what is called a bulk DC-DC converter. This simple device takes your solar system’s 12-volt power and converts it to whatever voltage you please. This complicates things because you will need to find a plug adapter so you can connect the converter to the laptop. Using a Bulk DC-DC converter can be incredibly useful for powering strange appliances that require weird voltages.
I will be charging these 2 laptops if possible:
1. Work laptop (Asus-like) --- 19.5v-- 6.15a--120w X 7 hrs .= 840 watt hrs.
2. Lenovo laptop -------------- 20v----2.25a---45w X 7 hrs = 315 watt hrs
Has anyone here used either of these ways to connect their laptop to 12v system?
1. (The easiest way to do this is to find a laptop charger that can plug into a cigarette lighter)
2. (If you want to complicate things, you can buy what is called a bulk DC-DC converter)
Thanks guys in advance,,
Blessings,
Russ
Blessings,
Russ
