Just bought 16 Eve LF280K A grade; update on degradation after 15 months
Surely they dropped more than what they made me save on electricity in one year. But one year ago, I was expecting energy prices to go higher than what actually happened.
For me, it was 18 months and I've saved more than the reduction in price.
I've finally bought another EBC-A40L and I'm currently testing the same cells I tested 15 months ago.
They have since been cycled 224 times.
I'm using the same logic as before: charge to 3.65V with cut off current of 5A, wait 30 minutes, discharge till 2.5V
Here is a comparison of my first retested cell
Time of test; Capacity; Energy
December '22; 278.4 Ah; 900.27Wh
March '24; 266.00 Ah; 855.91Wh
Capacity lost 4.4%; energy lost 4.9%
The only differece is that the first test was carried out at around 19deg (indoor) and the second one at around 15deg (garage).
Edit 19Mar2024
Second cell (#9) measured 266.90 Ah, 858.68Wh
So at the moment a pretty even loss across these 2 cells
I have now tested the one I believe to be the least capacity cell, because it's the one triggering the low voltage protection when the pack is fully discharged.
I did not test this cell when new, so its original capacity is unknown.
Its current capacity is 263.30 Ah, 847.58Wh (test conditions as above, temperature 15deg C)
Re-test it at 25°C for consistency with spec sheet. There will be some capacity loss at 15°C vs 19°C of about 1%. Between 25°C and 15°C there could be 2 - 4% difference. Then there is calibration factor between 2 different capacity testers.
