Charging voltage
slowbutsure
Hi
I have 16 cells to make up 14.2kw as a lithium battery. Anyone know what the charging voltage should be? Thanks.
It depends on how the charger is configured. If you can program the absorption time to a fixed 2 hours or more, then 3.45V is likely adequate if your BMS can be configured to balance in that range.
If your charger just runs up to 3.45V and then stops, that's pretty turdy.
3.40V may be adequate with a 5 hour absorption as I demonstrated here:
battery achieved 99.7% SoC with 0.02C tail current @ 3.40V/cell (13.6V).
You think it should be higher?
Absolutely
Useful balancing starts at 3.45v/cell. (Minimum 3.4v/cell)
55.2v is the lowest I would float at.
And bulk should be 55.5v .
Personally I charge at 57v bulk and 56v float.
But not everyone wants to, or can go that high.
This indicates you really don't have a basic understanding of charging LFP.
You can charge at any voltage you want to. The results will be different for every voltage. You probably need to clarify your intent.
My friend, was that necessary? It gets a bit old this “I’m an expert and you don’t know what you’re talking about.” But if it makes you feel important or better about yourself then you do you.
Yes. It was. This sort of statement:
I’m not asking for what the voltage is for when it’s fully charged. I want the charging voltage.
is nonsensical.
Why do you want a "charging voltage?"
To fully charge your battery or something else?
is nonsensical.
Because my inverter has a setting for it. Regardless, no it wasn’t necessary. You can contribute and be helpful if you want to, or say nothing. But to be insulting is not one of those two options.
Let's try a different tack.
Which inverter do you have?
Which BMS do you have?
Do you have inverter - BMS communications connected and enabled?
"Charging voltage" per-sé doesn't really have any meaning as your pack will be charged in constant-current mode for most of the time, only when approaching full does the voltage come into the equation.
