So there are 12x 50Ah cells configured as 3P4S?but 3P pouch cells in series.
Yes. I was a bit disappointed, but its what I have now and should be fineSo there are 12x 50Ah cells configured as 3P4S?
Are you bypassing the BMS to charge?Charging both batteries with 13.8V and 5A.
I keep checking the balance leads and set the voltage. As it gets closer I'll monitor more closely, but the volts should stay the same and the amp should start to drop as the cells absorb. Hopefully this is right. I did not want to tear these batteries down any farther to set in parallel. Thats way above my knowledge LOLAre you bypassing the BMS to charge?
If so, YOU are the BMS and need to monitor individual cell voltages. Once one cell gets over 3.45V the voltage to increase at a much faster rate. To properly top balance, you would want to charge in parallel or one cell at a time.
If I get these 2 batteries close enough to full SOC to put them in series and hook up the new BMS, I was hoping the balancer would look after the rest. Each of the 3 cells in parallel have now become one cell for me, which is an issue for me now. I'll never know exactly how each pouch is performing.I keep checking the balance leads and set the voltage. As it gets closer I'll monitor more closely, but the volts should stay the same and the amp should start to drop as the cells absorb. Hopefully this is right. I did not want to tear these batteries down any farther to set in parallel. Thats way above my knowledge LOL
It will pull 25W so it may get hot. But it will work, just don't let it overheat.Does anyone know if this resistor is ok to use for discharging the higher cell ?
Do this instead… set your power supply to 3.55V and directly charge each of the stragglers up to 3.45V it should be faster that way.One cell in each of my battery packs has reached the target voltage of 3.45V while the rest of them are all sitting right close to 3.357V. Does anyone know if this resistor is ok to use for discharging the higher cell ?View attachment 206124View attachment 206125
I'll deffinately do that. Way quicker for sure. I wanted to visualize the batteries in the space they will be living and had to remove the bms's to get the batteries apart. In hindsight, I should have just put them back on. I have both packs nearly perfect now at 3.450V/cell. 2 cells to go.Do this instead… set your power supply to 3.55V and directly charge each of the stragglers up to 3.45V it should be faster that way.
