I have recently incorporated a Champion 7250 watt (model 201176) open frame inverter generator into my Victron off grid power system. I did this because the electronics in my Electrolux front load washer did not like the power from my normal Champion, Onan, and Duramax generators. I also wanted cleaner power when on generator.
The main breaker system in the inverter generator is electronic, no real toggle breaker as with all the rest of the generators. I am only using 120v from the gen and have had to reduce the charge rate to 30a to reduce nuisance tripping. Still having some nuisance tripping while gen is running. Also having problems with gen picking up load when first started, the electronic main breaker trips. Never had any problems with this using any of the other generators.
Anyone out there with similar problems?
