I should hope there would be change left over.
It isn't in the same class at all.
Have any motors you need to start?
If I was you I'd want to figure out how to make the Sunny Island work.
I'd be quite happy to pick up 1x SI 6048US and 2x Classic 250 for the price of a DIY.
Cheap, but low or no stock.
Shop now for MidNite Solar MN5048DIY MPPT Hybrid Inverter/Charger 120VAC 48VDC 5000W.
www.stellavolta.com
With excellent surge capability, the DIY Series will start the most demanding 120VAC loads. Manufactured for MidNite Solar in China. Max Rated Power: 5000W. Max PV Input/Output Power: 5000W. Algorithm: MPPT.
www.ebay.com
The DIY line was just a relabel.
Midnight's "The One", 10kW AIO, may be more capable.
But if you want an Art Deco replacement for German Engineering, Rosie is the one to consider.
