Due to lack of space and free contacts, I am considering using a 12V outlet connector as an input point. Let me explain better:
in normal conditions this 12v outlet is used to draw power from the house battery, with traditional 12v car chargers
if, instead, I used this outlet to bring power to the battery, for example via a 220v-12v charger, could this cause problems in any way? the outlet is a quality one declared 20A, as are the cables I used, and my input would only be 10A
the 220v charger will only be used occasionally, that's why this flying connection
Am I missing something, or is this perfectly doable?
