I’ve got 2- 12v 115AH FLA batteries in parallel (12V 230AH) connected to a 3000W inverter.
Just performed first test, and these are the results:
-1200W microwave operating for 30 seconds
-battery voltage prior to test = 12.84v
-voltage dropped to a low of 11.93v during test.
-once microwave stopped, voltage read 12.72v
-5 mins later, voltage stabilized at 12.91v
my question is in relation to the low reading of 11.93v during discharge. How does this low voltage reading relate to the %depth of discharge? I’ve read starter batteries drop to 9-10v during starting.
Will recommends a low voltage cutoff of 11.5v as the setting on my all-in-one (separate system) even though a battery shouldn’t be discharged below ~12.1v, and I guess now, I see why, as I’ve been confused about that.
Where can I find a good read regarding safe levels of voltage drops under load, in relation to depth of discharge?
