As far as I know, I'm only supposed to keep an eye on the battery fluid level and add distilled water when needed. But after doing this over and over for years, doesn't there come a point when I should be adding more actual acid? It seems like the original acid solution that existed when I bought the batteries would be overly diluted at this point.
Thank you.
Thank you.
