D
Hmm i use them a bunch. Never had an issue.
@New Mexico Will, thanks for the heads up. I had ordered 3 yesterday and just cancelled it. I want to think about things a little more before I pull the trigger on something again.I just went through all 4 I had (2 to use, 2 for backups). I just made the upgrade that pushed me to a potential of 30 amps, from about half that, and they started failing. All 4 are in the trash bin now.
Thanks. Were your bad ones Kumeed (like Ped) or something else?I ordered these and will install them this weekend & report back.
I was looking at that style on Amazon for my 30a draw trolling motor and saw many of the reviews say the same thing, couldn't handle continuous current and tripped way below their rating. I just used a ANL fuse instead.
You're a mind-reader. I was just going to try and pull you into this!I gotta say... the Bussman Series 285 surface-mount 40A breaker (of which the T Tocas is a knockoff) is only $38.00. I know the T Tocas is half the price (or more? I didn't see a price in that screenshot), but I very strongly feel that reliability and trustworthiness in a fuse or breaker that's protecting thousands of dollars worth of equipment is well worth the additional investment to get name-brand.
Didn't you suggest some din rail breakers as well at one point? I'm trying to find that thread.I gotta say... the Bussman Series 285 surface-mount 40A breaker (of which the T Tocas is a knockoff) is only $38.00. I know the T Tocas is half the price (or more? I didn't see a price in that screenshot), but I very strongly feel that reliability and trustworthiness in a fuse or breaker that's protecting thousands of dollars worth of equipment is well worth the additional investment to get name-brand.
Here's the link to the 285 series on our eBay store, just for comparison: https://www.ebay.com/itm/Reset-Ther...PGWwJyfAWBI0tTw:sc:USPSFirstClass!92120!US!-1You're a mind-reader. I was just going to try and pull you into this!
Yeahhh I was recommending the MidNite Solar MNEPV breakers for PV>controller breaking specifically, since they go to high voltages... they're great on the controller>batt side, too, they're just usually unnecessary because you'll be at a lower voltage on that side and can use cheaper 187 or 285 breakers.Didn't you suggest some din rail breakers as well at one point? I'm trying to find that thread.
Ah! Fair enough! Bussman (or Buss or Eaton Cooper Bussman) is the name to look for in quality breakers/fuses/etc. They're OEM for all of Blue Sea's fuses and breakers (ie, the Blue Sea 7182 = the Bussman CB285F-40 in Blue Sea's packaging) as well as OEM for a vast number of automakers and home electrical systems (when you're in Home Depot and see Cooper light switches or breakers, it's the same Cooper as Eaton Cooper Bussman).Well, half the battle is knowing what's out there. I'm running blind here, going on Amazon reviews and what I see here. Two of the Tocan knock offs were $47 shipped.
