My setup is fairly similar: 26 x 102 ctc with 2000w pv and most likely 24v 408ah lifepo4 ... 9000btu senville inverter heat pump split.
My goal is to run the split off of solar here in the west ... at least during sunny hot days (thankfully there is usually not much need for nighttime ac in the desert)
However, a Honda 2000i going thru the victron multiplus inverter is the backup plan ?
