Yes, a rechargeable battery can be refilled, just like a gas generator needs to be refilled. But the battery sill transforms chemical energy to electrical energy via a chemical reaction.
Go look up how batteries work.
Batteries BOTH store energy in the form of chemical potential energy and transform that energy into electricity via a chemical reaction. That's, in fact, how they work and have always worked. Where THIS group benefit is that smart people have found a reversible reaction so that you can turn that reaction back around and turn electrical energy into chemical potential energy.
I'm not making any analogies- this is how they actually work.
Your functions are not complete, BTW, as both the battery and mechanical generator transform chemical energy to electricity.
For something that just stores electrons (aka raw electricity) to use at a later time- that's a capacitor. Not a battery. Batteries don't just store raw electrons, they reverse a chemical reaction, which can keep going back and forth.
And I'm not talking about what terms to do what- I'm just explaining what stuff does- you can use whatever words you want to describe them.
It's funny that you suggest that a generator can make electricity without continuous input. If not for a constant supply of fuel, they would not run. And I know that the right size battery will output electricity longer than a gas generator with a tank. Gas generators don't make electricity out of nothing....
You are hung up on the word "generator"- which is largely been mislabeled technically, but it works, and it stuck. Just like the use of Watt-hr is very confusing to many, when the technical correct unit of energy is Joules. But it works and that's ok.
