Hi. So, there is a persistent misconception that the line voltage from your charge controller to your battery IS the batteries voltage, and if it is off, there is something wrong with the system.
This is inaccurate.
The charge controller "charges" the line from your "charger" to your battery.
In the "First" Images 1 & 2, you see the Batteries BMS shows a Voltage of 13.6, and the Charge Controller shows the Voltage of 14.7
In these images the System is on, and charging normally, the charger is receiving energy from the solar panels and then sending it to the battery by charging the line from the controller to the battery. (The BMS is showing the actual voltage of the battery.)
In the "Second" Images 1 & 2, you see the BMS AND the Charge Controller read the same exact voltage of 13.4/13.5v This IS the Batteries Voltage. I unplugged the Solar Panels from the Charge Controller so there was no current, and you can clearly see, the Charge Controller immediately dropped the reported voltages down from 14.7 to 13.5 BECAUSE: THERE WAS NO CHARGE ON THE LINE. 13.5 IS the Batteries Voltage.
In the "Third" Images 1 & 2, I reconnected the Solar Panels and the system is back in normal operation. And again, the Charge Controller shows the voltage as 14.7, while the Batteries BMS shows the Voltage of 13.5 - Again, the Charge Controller "Charges" the line from the Charger to the Battery.
The wires from my Charge Controller are 2 feet long and 8 AWG - 8 AWG is rated to handle 50 Amps.
There is no issue with the system, equipment or devices, what you are seeing is common with PWM, Lead Acid, MPPT, LIFEP04, or any of the configurations and combinations you can imaging for a Solar System receiving a lot of sun, charging the line and putting amps into the battery.
This is normal. Anyone saying that the "Charge Controller" line voltage is the Batteries Voltage is incorrect.
I am in the process of doing just that, I will use my Lead Acid Batteries and PWM that I have replaced as I have upgraded the components on my system, I will buy and use heavy gauge wires, I will use MPPT with Lead Acid, PWM with LIFEP04 etc, and make a video so people can see, with any configuration, with enough solar, your charge controller charges the line and it is NOT your batteries voltage - and that is normal and how electricity works.
Please make sure to look at the images.
This is inaccurate.
