Use the acme or heyco pv module wiring clips. I wouldnt use much of any of the other offerings.
Thomas and betts, panduit, or some other good 45 and 55 lb black zip ties get plenty and twice what you think is plenty. We zip through 300 easily on medium size systems even though we hang wire on stainless rail clips every 2 feet and wherever else needed.
Zip ties..... they can work outstanding in the right situations, bundling, turn buckling, securing but we strive to have no wiring relying entirely on zip ties to keep the management.
Int he photos are one of the mounts like yours.... you will have to "pop the hood" on each module, have someone lay it down and sandwich you in there to get it. I slide out the side while holding the tail of the last zip tie and wire and pull tight in place as they lay it down on the mount. Not fun at 90° especially on asphalt shingles, but i do every single one for quality control.
The ground mount shows the way we secure wire forever! We do this on rooftop stuff too if its in the budget. Cusion clamps, listed ones amd stainless with stainless tek screws..... its my perosonal guarantee that your wires will never sag below the rails And will will never lose zip ties to time amd cold etc., allowing the wire to get snagged, pinched, blown bac and forth until there is a hole in the jacket or ever touch your metal roof.... 1$ apiece and worth every penny.
