I have a finished-out 28-foot cargo trailer I use as my hunting residence/cabin. I typically connect to 30 amp shore power. I hunt and park it in West Texas with a ton of sun year-round. I'm a solar junky and I was bored, so I went looking for a new project to trick out my trailer. I have the perfect trailer to add solar so I decided let's take it totally off-grid. I started by purchasing eight 250-watt panels from SanTan. Then I moved on to researching what other components I needed.
I came across Will's YouTube videos and website and the wealth of information is awesome. Buying everything separately seemed straightforward, but putting it all together can get a little overwhelming. I'm not usually at my trailer long enough to hunt and do major projects, so figuring out how I'm going to get it all done before 2030 is my challenge. I watched Will's video about Point Zero Energy Titan Generators and instantly thought that is what I need! I can handle mounting the panels on the roof, wiring them appropriately, and connecting them to a Titan. Instead of plugging into 30 amp shore power, I can simply plug into the Titan 30 amp port. Am I missing something? Can it be that easy? What else do I need to consider?
The Titan ain't cheap, but everything is self-contained in a box where I can add as many batteries as I need with 2000 watts worth of panels keeping them topped off. That's way easier than parting everything together myself and hoping I do it right (watch Will's Top 10 Mistakes New DIY'ers Make). My only concern is my trailer is left unattended on the property for long periods of time. I'm not concerned about theft, but I am concerned about leaving the Titan and solar hooked up for that long. Should I be concerned about this or are there enough safeguards in the Titan to let it go? I appreciate your input!
