ImAnIdiotPleaseBePatient
- Dec 10, 2022
- 433
For the low price of $100, I will point out the flaw in your little scheme.So if he saves $100 by NOT giving you $100 then he's got $100 free to give me it's a win win
non-consecutive 20’sSounds like a bargain, how would you me to pay ?
hell, i will settle for a single non-consecutive 20non-consecutive 20’s
And the award goes to @ImAnIdiotPleaseBePatient in post 129.For anyone reading this thread and looking to get into solar/off grid living/van life etc, the lesson is:
You cannot trick a grid tie inverter with a fake mini grid cheaply/easily
People have done it with more complicated setups
the next step:
Here's a list of all the inverters mentioned in this thread that will work for my situation:
POWMR
MidNite Solar
Schneider electric, make sure hv input
Sol-ark
Voltronics
SUNNY BOY STORAGE 3.8-US / 5.0-US / 6.0-US
Some of these are very cheap quality, others are very high quality but very expensive
I now will start the search for the proper inverter
If anyone has one laying around, let me know
Also I probably have to sell the PVI6000 to try to recuperate some damage
But he's also saying to sell the prius, which is insaneAnd the award goes to @ImAnIdiotPleaseBePatient in post 129.
Search results for query: Sell
diysolarforum.com
@joesmith123 I hope you learned a lot and thank you for your testing.
Be sure to post updates on what you choose. We are here to help, even if you don't listen the first time. (I'm stubborn too, when someone tells me it's not possible it makes me want to try that much more...)
I'm still holding my breath for you to try this option. No need to send me $100; save it for the hospital bills!
Did you read my post before responding? Your "smart" (not smart, it is a bog standard grid tie PV inverter) has a 5 minute timer. In the seconds the little inverter was powered up the PV inverter never even got to the point of producing power.
Yes the aurora is not suitable for my situationWow.
I'm sure it's been covered, but I feel the need to say something.
Your Aurora is dumb. no offense, but it has one job: deliver as much power as possible to the connected grid. Period. It's not going to moderate itself in any way if an acceptable grid is present.
In order to use it, you need to AC couple it to a grid. You can do this with an inverter capable of frequency shifting. These work by sensing the surplus power at their output and using that surplus to charge the battery (which you will need to buy as well). Once the battery is full, it moves the grid frequency far enough off of 60Hz to cause the Aurora to effectively decouple from the grid.
The inverter selected needs to have the same power rating (sometimes 20% higher) than the output of the Aurora.
Your 2011 Prius HV battery is likely no more healthy than 50-60% of it's 1.3kWh rating. A new 12V battery for the Prius has about the same capacity (45Ah * 12V = 0.54kWh). Additionally, the Gen3 eat engines. Make sure you change your oil every 5k mi and check it regularly. Most burn it. If you ever have your head gasket warp on you, do not replace it. Get a new engine. Lastly, your fuel efficiency is going to be way worse than a suitably sized generator AND the car will run almost constantly. It will be nice and quiet though.
IMHO, between what I know about solar, and what I know about the Prius, what you are doing is pointless. Your Aurora is more of a burden than a solution.
To the run the prius for one week cost me about $20-25, and it doesnt run constantly, I have been living on it for 7 months now, not one issue
So what's the issue now , Is it that you can't get enough power just from the 12v side ?
Not sure about the OP, but for those that do this regularly, the DC-DC on the Prius is about 70A, so peak "generator" output is about 700W after car loads.
To be fair, I thought it was just the prius battery. I reread and saw you have the actual car. Should have deleted that.But he's also saying to sell the prius, which is insane
It is literally the best bang for the buck generator, ive been living on it for 6 months straight no interuption (just the 12 volt side)
Yes, going through the high voltage will allow me to run machines, mutiple ACs, multiple fridges, etcSo what's the issue now , Is it that you can't get enough power just from the 12v side ?
With that setup, it would be going from 220VDC -> 12 VDC -> 24VDC -> 110VACSo how about this @joesmith123
the Prius can do 700ws an hour from it's 12v ,if it can do it constantly, thats 16.8kw a day
I'd go:
A boosted mppt from the Prius, 12v >24v ,
24v battery bank of your choosing, and a normal bog standard inverter to run your loads
Simple easy viable solution.
Depending on inverter/ battery choice ect.. (I'd go AGM), . I reckon you could do it for less than $1,000
.... that's not including my $100 of course ?
The better route: 220VDC-240VAC
