Overpaneling over a 100% of what a controller can take. Offgrid
Derka181
Canada
I’m going to overpanel my 40a renogy solar controller (12v / 520W) and in theory it should work. My renogy controller is 100vdc and my panels are 535w each. Each panel has approx 50v and 12.5 amps. I will be wiring these panels in parallel using 8 awg wire. 8 awg wire can do 40amp . So these 2 panels in parallel will only be at approximately 25amps at peak times and my solar controller with only be using 50v of my 100vdc. I heard a guy say that the panels don’t push power to the control the controller takes what it needs from the panels. And gave an example like this…..A light in your car uses 20w/ 1amp. You battery doesn’t push its full power to the light. Think of your solar controller as the light . The light will only take what it needs from the battery, as long as you are below the specs on vdc.
Am I wrong, and is this a bad idea?
I just had 1200 watts (4 320 renogy panels wired in 2s2p) connected to a renogy rover 40a CC for the last 9 months in very sunny souther California desert. Didn’t seem to be a problem other than I was almost constantly pulling the max amps out of the controller and it would get fairly warm if ambient temps were in the 80s. I put a fan on it and it seemed to take care of the problem. Also my battery would go into float by 10am so overheating wasn’t too much of a concern.
I do overpaneling with a 15 amp Victron controller I’ve used over 100 times and have once had an overamperage error, but nothing hat slowed production.
Really comes down to you accepting the risk of something going wrong, and has mentioned, the possible shorter life of the charge controller running all out possibly all day. My SCC is a portable setup sitting outside.
Victron give very detailed guidance on overpanelling. Renogy/Epever etc just seem to say 120%, 150% etc. Its mostly hownthe controller would respond to a malfunction. Eg whether it would melt down.
I don’t understand the straight polarity and reverse polarity in the above post.
Are you using 8 awg wire or 10 awg?
My take on it is hooked up correctly "straight polarity" it just takes what it needs so no danger going over like crazy.
Hook it up backwards by mistake "reverse polarity" the built in reverse polarity protection which keeps from frying the controller can be overloaded when over paneled and BOOM goes the controller aka fried.
I also want to add for my 15 amp Victron SCC that maxes out at 24 volt absorption voltage at 420 watts I put 900 watts of panels on it.
This Victron allows me to hook panels up where open circuit amps exceed the 15 amps of the controller.
My actual max amps in at 66 volts us 13.5 amps, but the SCC is limited to
15 amps out X absorption voltage = 420 watts
So even though my panel watts exceed the wattage max out of the SCC by two times, I could add more panels to stay under the limit.
Absolutely no problems with overpaneling. I have 3750 watts in panels going to a Growatt 2000w inverter. At mid day, the inverter takes 2200w. It still wouldn't be a problem if I had 10000 watts in panels. The inverter will only take what it needs. The only risk is if somehow the MC4 cable got cut or damaged in such a way that it would cause a short, it would burn up pretty quickly, rather than burn up slowly. But then burning up quickly might be better, since it would be kind of like a fuse.
I had over 80a worth of panels connected to an 18a max SCC. It ran like this for several months.
No issues at all. It just pulled the 18a for most of the day.
Sounds like you’re mixing up the PV current and charge current?
