Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,233
Never knew such a thing existed. I have to research if there is any available in the US market. My ~28 year old 240vAC dryer is an energy hog but it does dry things (a typical load in under 40 minutes). I can not power it from my PV so it like my electric range ( almost never use it with all my countertop cookers/ovens) remain grid powered. Like others mentioned a clothes line can handle clothes dryer duties if needed.
Yes, they're in the US, several brands and multiple technologies for ventless.
I got a Bosch condensing dryer that is air-cooled, due to no vent in a rental condo. It does dump excess heat in the room (but not moisture like previous conventional one.
Washer/dryer combo, which I got second hand (Fager) and used until it stopped working, uses cold water to condense.
Then there are the heat pump. More expensive, like $1300 vs. $1000 (vs. < $500 for common brand conventional dryers.)
I would expect these to be more economical.
Make sure condensing dryers are flat. I put on a shelf which sagged, and water didn't run off to pan so didn't dry. (placed over a top loader so couldn't stack as intended.)
I think the power requirements may be the same in terms of circuits and receptacles but the power consumption is a lot less for any heating task. No wasted heat because only the pan gets hot. There is no heating element that has to transfer heat to the pan, which is why induction heating is more efficient.
Anybody got inrush and power factor data or scope traces for these?
I could imagine them being nice or nasty, depending on how designed.
Makes a difference on how much inverter is needed.
