2strokeforever
- Dec 12, 2022
- 31
If anyone has a XW pro working with a wattnode I could use a hand figuring out how to set it to zero export.
There is a bug in the software where the dashboard screen says the opposite flow direction to the wattnode screen.
What I would like to know is:
Which way is current flowing?
What color are the Leds on the wattnode?
What flow direction on the dashboard?
What would you set the export limit at to use 1kw from the grid before the inverter starts chipping in? 1000w or -1000w?
If you are running a heavy load and suddenly shut it off does it let some power back to the meter, or is it truly zero export?
Have you seen"RED" flashing on your power meter? (reverse energy detected)
I have sent a dozen emails and a video back and forth with schneider before they admitted/ figured out that the screens were reversed (which I very clearly explained each and every email). I dont trust the guy I was talking to enough to risk hooking it up backwards.
I am not allowed to sell, otherwise I would flip a coin and see what happens. I have no idea how sensitive the new power meters are to reverse flow, and dont really want to talk to the power company.
Heres a link to the video I send schneider that shows my problem.
