A aKO New Member Joined Jan 3, 2022 Messages 45 Jul 29, 2023 #1 What are users mounting their Inverters , Charge Controllers and associated equipment on . I am in Spain and getting anything other than Wood or Steel sheet is very difficult .
R rodrick Free energy enthusiast Joined May 8, 2022 Messages 1,228 Location Wa soon to be Mt Jul 30, 2023 #2 Cement board over drywall works well
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 19,301 Jul 30, 2023 #3 Steel sheet is perfectly fine.
HRTKD Boondocker Staff member Moderator Joined Apr 24, 2020 Messages 10,029 Location Somewhere South of Denver Jul 30, 2023 #4 rodrick said: Cement board over drywall works well Click to expand... This isn't what I did, but if I was doing it all over again, I would do it that way.
wildbillpdx Solar Enthusiast Joined Jun 24, 2023 Messages 398 Location Oregon Jul 30, 2023 #5 rodrick said: Cement board over drywall works well Click to expand... I used cement board over plywood (helps with mounting) over drywall.
Mattb4 Solar Wizard Joined Jul 15, 2022 Messages 4,226 Location NW AR Jul 30, 2023 #6 You should be able to find fire rated drywall (plaster board, sheetrock) to put over plywood for mounting strength.
