timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 19,424
I run the dryer sometimes, when it's empty.
Just to watch the solar production go up. lol
That's a good 6000-7000 watt bump right there, must be nice to watch!I run the dryer sometimes, when it's empty.
ME TOO!! Except its my hot water tank on the smart load lol!!I run the dryer sometimes, when it's empty.
My TriStar mppt shows both what I am using loads/batteries and what the arrays are getting/potential wattswish the inverters would say how much portential solar there is, and how much is not being used, there must be a way to do this?? It can be full sunny, but i'll only be using 1000 watts of my 10.7kw, I want to see how much solar potential is being wasted.
maybe someone has answers to this!
Do you have a link to that unit?
A number of friends have asked similar questions.
Can it link to Home Assistant or the like to control a dump load??
How does it do such a thing? Historical data? Surely it's not somehow pulling a high load and dissipating it somehow.My TriStar mppt shows both what I am using loads/batteries and what the arrays are getting/potential watts
I'm guessing it's historical.. whenever it ran it's last sweep? How often does the sweep number change and how quickly? If you put your hand on a panel, how long til the sweep pmax number updates?Maybe magic?
This is what I see:
The "output power" is what is being used.
The "sweep pmax" is the potential
Correct, that value is per sweep, the "output power" is live. I don't know how long between sweeps, never timed it or looked to see if it can be changed, my guess is about every 3-5 minutes. It's close enough for me. Occasionally when the batteries are nearly full and the array is hitting it's peak, there is about a 2kw difference in those values.I'm guessing it's historical.. whenever it ran it's last sweep? How often does the sweep number change and how quickly? If you put your hand on a panel, how long til the sweep pmax number updates?
The beer can heaters in the windows will net you zero gain. Better to just let all the sunlight come in through the windows directly.We built our house new in 2016. North Carolina so more heat problems than cold problems. Energy star rated, spray foam, all electric so we went with a heat-pump water heater...and it's "the tightest house I've ever built" according to the builder. We got a great rating on the Energy Star rating.
It's tight, but the half-buried/half walk-out basement was unfinished and only the ceiling was insulated (spray foam). Throwing insulation in down there cut demand in the basement (less need for a space heater in the winter, or a portable AC unit in the summer). I also have to run dehumidification down there...and I replaced the traditional dehumidifier that blows out hot air with a Midea "u-shaped" window unit that dehumidifies and dumps COLD air into the basement. I can run it 3 hours a day using 300watts/hr to handle all of the cooling/dehumidification over the summer. Huge benefits. Before I was pissing into the wind with a dehumidifier that was heating...then running a crappy portable AC unit that was struggling (and sucking in more humidity to make the dehumidifier work harder).
This winters project is building a few "beer can solar heaters" to throw in the south facing windows and see if I can bump the temp up a few degrees and run my space heater less.
Other than that, I can't bring myself to close down the hot-tub. It uses 7-10kwh a day...but after a day trenching the freaking yard there is nothing better than a hot massage.
Im in DFW and in the summer i kept my house at 79 cos the mini split kept it so darn dry that any cooler was to cold for me.In the summer the MASS of the house gets heated by the sun. In the winter, there is not enough sunshine most days to heat that mass to any useful extent. It is also heating the attic space that I am trying to isolate the living space from. If I could absorb the heat from the roof and transfer it to the floor in the winter, I would do black or a darker color, but I can't, so I won't. Same reason you don't want a dark colored ice chest and the lids are almost always white. What I really need for the winter is a thermal floor! For now, I'm just glad I'm on a slab foundation.
What part of Texas are you from? Our ambient humidity is high year round as the typical weather pattern is air from the gulf blows into southeast Texas then up into Arkansas. In my shop, if I can keep the humidity below 45%, I can tolerate temps in the 80's (85 feels pretty good when It's 105 outside.) So if the spit can keep it below 50% at 78F, I'm "golden". (I'm getting old and liking the warmer temps I hated when I was a fat kid.)
Now, beer can heater outside not blocking a window, that could
I have a Midnight Classic 250 CC, with 1800w solar, charging a lithium 48v bank. The battery bank is discharged by microinverters, AC coupled back to the main battery inverter system and house loads. The charge controller communicates with battery voltage and pv voltage, read by a raspberry pi. When the battery is nearly full, the charge controller would stop charging the battery, wasting solar, Oooohh Nooooo!!!!I wish the inverters would say how much portential solar there is, and how much is not being used, there must be a way to do this?? It can be full sunny, but i'll only be using 1000 watts of my 10.7kw, I want to see how much solar potential is being wasted.
else if (msg.topic==="MN_PV_V_sm"){
mnpvv=msg.payload;
context.set("MVPVV",msg.payload);
if (dcvpc>4.02){
mindcl = global.get("MinDCL")||0;
if (mnpvv>100&&mupcnt<1){
mindcl += 1;
mupcnt = muprate;
context.set("mupcntr",mupcnt);
else if (mnpvv<92&&mupcnt<1){
mindcl -= 1;
mupcnt = muprate;
mindcl = Math.max(0,mindcl); // limit to available range
mindcl = Math.min(12,mindcl); // mindcl max of #micros in DC cabinet
dclr = mindcl+0.5;
global.set("MinDCL",mindcl);
else {
mindcl -= 1;
mupcnt = muprate;
context.set("mupcntr", mupcnt);
mindcl = Math.max(0, mindcl); // limit to available range
mindcl = Math.min(12, mindcl); // mindcl max of #micros in DC cabinet
dclr = mindcl + 0.5;
global.set("MinDCL", mindcl);
This is a consumer based economy. You need to do your part and consume. It might not make financial sense for you, but have you considered the quarterly profits?Just looked up the numbers on my nothing special bottom freezer refrigerator that I bought used for $250
Costs about $5 a month to run. I'm not going to worry about getting more efficient than that
So true. I would run my air conditioning and electric heat more if it were "free".A few thoughts.
When I decided to install a solar system for my house, it was designed and built so we could live our lives the same or better than before the installation. This means not living like a hermit in a cave or being single and not having a partner.
We have actually increased our electrical usage. Part of the reason is shifting energy sources to electric instead of propane. Even though we increased the Kwh used per day, each shift to changing energy sources was done with efficiency in mind.
I prefer living my life to the same or better standard of living I've always enjoyed.
