Growatt SPF6000T dvm beeping
LuisGenesis
Hello all,
I have the Growatt SPF6000T dvm, i normally have it off and use it when power goes out, I've notice that every time while in the off position when the sun comes out and it start charging the batteries it turns on by itself and does the a loud beep as if i was turing on the inverter to be use. I wonder if there is a way i can turn that beep off when the MPPT wakes up to charge the batteries while is on off position,
thank you
I have a different model, but possibly try changing setting 15 (alarm control) and 17 (beeps while primary source is interrupted)?
Hello all,
thank you
I’ve got the same inverter. The Beep can be disabled! It says how to do it in the manual. I don’t have it in front of me at the moment but it’s possible.
I don't think disabling the beep is the answer. The question is why is it beeping and what error code/fault are you getting?
You can turn it off in the menu although it will still beep in certain circumstances or open the unit up and fill the beeper with snot or modify it with your favorite pair of pliers ?
The alarms can be turned off in program 15 and program 17. I just think it's good to know when something is not right.
