LV6548 is 6500W per leg on a pair in split phase.
The 6000XP is rated at 3000W per leg. A pair would still be rated less.
I would not purchase a newly released inverter until the bugs are worked out. The 6000XP has been beta tested but I would not be in a hurry to purchase just yet. Many here have learned that lesson. Latest and greatest until the honeymoon is over.
5S2P on the 6000XP would be over 17A. Even if the MPPT just clips the amps, it actually is a waste of PV power, some say to do it because the power is spread thru the day but it still wastes power. With the 2 EG4 MPPT's I have installed, I can pull full available PV from the array and it goes into my battery bank until 100% SOC.
If the LV6548's are working fine, I'd just add a pair of EG4 MPPT's like I did for higher string voltage if you are after higher string voltage for a reason. Later, if you decide you want to add more PV, then you could purchase panels that fit the LV6548 MPPT's better and use the MPPT's in the LV6548's.
In all respects, if you have 10 panels, just run 3S into 3 of the LV6548 MPPT's. You end up with an extra panel, not a big deal. Or run 4S into 2 MPPT's and 2S into a 3rd MPPT.
Only reason my string voltage is high is due to the distance from array to MPPT. I have no idea why you would want to change inverters.
