I recently got a 12v 230 ah lithium battery. I did a load test to see if it could provide the 200 amp limit which specifications said it was capable of. In the video I showed how I determine the correct charging and float voltages, how to use DC rated clamp meters, compared the bluetooth bms readings to what the meters said, and also did some math to show how long various loads would run on the battery. I tried to make this beginner friendly on explaining things. Hope it is of value since there are usually a lot of questions about this on the forum here.
