I removed the nickel strips from the negative terminal using diagnal cutters. I grab and roll to remove the metal. I noticed on some of the tough ones the negative terminal raised. I ran a capacity test using an xtar vc8 plus and its in the 2700mah range. bat spec > 2500mah. it is hard to see in the image but there is a high spot from trying to pull the strip off. Can these be used? Eventually it will be used in a powerwall.
