bluenomads
- Aug 4, 2021
- 17
For the boat, the electric motors will likely be 48V DC, 20kW, but we'd only ever run 15kW continuous - partly because of the battery pack, but largely because we want range not speed!
Battery is 48V, 16S 304's, and at 1C can produce 15.6kW at 52V (for about 80% of an hour or 48min; we'd almost always be around 5kW).
I'm limiting voltage to 48V as the other items off the battery pack - inverter, charger, solar panel MPPTs and even windlass and bow thrusters are all relatively (!) easy to get compared to higher voltages.
BMS is JK which together with an external contactor can handle up to 500A.
Could I get a check my fusing and wiring sizes:
- Class T fuse right at/next to the battery of 350A - correct?
- I'm having trouble with wiring size since 300A isn't "normal" ...
- 120sqmm is the largest I can easily get, and I've read different opinions on whether that is enough for 300A. - Will that be enough for a 1.5m run (not including return) of 300A?
- if 120sqmm isn't going to be enough, what can I do??
- I could go double 70sqmm (2 x 00 AWG) = 140sqmm instead.
Or double 95sqmm (2 x 000 AWG) = 190sqmm.
However, I read of possible problems with multiple wires as the resistance of one may be slightly different to the other, and even if separately fused (175A?!) it won't fix the resistance problem.
Thoughts? - Other options?!
