Background: I live out in the country and utility power goes out often. Eventually looking to install ground mount system with batteries but not in the budget at the moment.
Main panel feeds: well pump, booster pump and house sub panel. main panel to sub panel distance = 300ft
I have a 10,000W 240v 50a generator that powers my home when the power is out via a manual transfer switch.
I have a water tank that can supply the house for a few days so don't need to run the deep well pump in an emergency outage.
I would like to run the booster pump so we have water at the house when the power is out.
Here's what I'm thinking and budget is the priority at the moment.
booster pump = 1hp, 230V 6a - I'm assuming a 1500W inverter would be sufficient. 6a is the only listed amperage on the pump so is that the max it would surge?
The pump runs for less than a minute at a time and not very often under normal use.
Can I use a 1500W inverter with 240V output, a charge controller, battery and solar. Can I put a manual transfer switch in between and just run the pump full time off the solar. If cost is the driver and the power goes out maybe 20 times a year should I just buy an additional cheap generator? can I use (2) 120V legs from either an inverter or generator to power a 240V motor?
Would love any thoughts, suggestions, alternative ideas.
