Hello everyone,
I’m sorry for asking this question which is probably already answered, my lack of knowledge about this topic and too much information, lack of battery datasheet confuse me a lot so I have to ask it in the hope, that someone with more experience can give me advice (if required I can pay).
My OFF Grid 8kW solar system includes:
8x JINKO Solar panel 315W
1x Sole Uni Max MPPT 8000VA-48V
4x LIFePo4 12.8V-200Ahm lithium-ion battery, 2560WH
Battery balancer
Connected devices:
Fridge (all day), TV, boiler (which is turned ON only over day), mobile/laptops charger, couple of bulbs
What would be the best stability and long live parameters for my batteries?
Right now I use battery type = User with default parameters and I'm scared that I may brake something with it (read long story).
When this type is selected according to the manual I Can change the 26, 27, and 29 options.
05 - Battery type = User
Available - AGM, Flooded, User, Pylon, Weco, Soltaro, Lib, Lic
26 – Bulk charging voltage (C.V voltage) = 56.4V (default!)
Posible range – 48V to 62
27 – Floating charging voltage – 54V (default!)
Possible range – 48V to 62V
29 – Low DC cut-off voltage – 44V (default!)
Possible range: 42V to 48V
Should I maybe follow Will Prowse's suggestion in this thread?
48V 16S LiFePO4 Battery w/ BMS
Absorption: 58V (for long live 56.4V)
Float: 54.4V
Inverter Cut-off: 42.8V-48V
Long story if someone wants to know why do I ask this:
I ordered the OFF Grid 8kW system and it was installed by the dealer. I tough it will be “good to go” but it was not.
The dealer told me the battery came at 100%, and when he connected it, they were at 50% according to the inverter.
The first night after installation I spent 25% off the battery and the next morning I had fault 04 (low battery).
That sunny day battery did charge to ~50/55% and again overnight I spent 25% off the battery.
On the next sunny day battery did charge from 25% to 80%, but after using a 1600w vacuum cleaner for only 10 minutes (while solar panels were producing ~400W) battery went from 80% to 49%.
As the dealer doesn't answer calls I checked settings and accidentally (at night) changed "Battery type" to "user". After a couple of minutes in WatchPower App, the battery status showed from 50% to 80%, according to the app overnight I spend around 10-15% of the battery and the battery gets charged really fast to 100% over the day.
But I'm scared if this is fine for my system as I don't want to overkill anything and reduce the life of components.
Battery balancer
Connected devices:
Float: 54.4V
