TL:DR What makes the HIKuBLACK double the halfcell bifacial?
So I'm narrowing in on what I want out of a panel. 390W seems to be a sweet spot for now when you consider I'm building a ground mount. (Weight per panel, cost of mounting lots of little panels vs big ones, wire on and on... )
I started looking at the CS 390W Hiku black's. they are 330 each with free shipping over 10.
Rated Power Output | 390 W |
Voltage (VOC) | 44.1 V |
Maximum String Voltage | 1500V |
Cell number |
Cell Type | Monocrystalline |
Rated Efficiency | 19.2 % |
Connector Type | MC4 |
Backsheet Color |
Frame Color |
Dimensions LxWxH | 76.4 × 41.3 × 1.38 in |
Weight | 49.6 lb |
Pallet Qty | 30 |
Manufacturer | Canadian Solar |
Manufacturer Part # | CS3N-390MSHiKuBlack |
Operating Temperatures | −40°F to +185°F |
Scope of Application |
Use |
Warranty | 25 Year Product and Performance Warranty |
Delivery Time | 5-7 business days |
Then I see the New Canadian Solar 390W 144 Half Cell Bifacial Solar Panel for 180$ but Santan Solar wont show me shipping until checkout.
Specifications:
- Rated Power: 390W
- Open circuit voltage (VOC): 46.8 V
- Max power voltage (VMP): 38.3 V
- Short circuit current (ISC): 10.74 A
- Max power current: 10.19 A
- Maximum system voltage: IEC 1000V and 1500V UL certified
- Fuse Rating: 25 A
- Weight: 62.6 lbs.
- Dimensions: 83.9 x 41.3 x 1.2 in
