Hello all,
I don't think this is particularly dangerous, but it's not typical, so I figured I would post it here.
I'm wondering if there's any reason why you couldn't pretend that a 7s LiPo is actually a 24V lead battery. Looks like from a bit of Googling that the absolute maximum voltage that a 24V lead charger will put out is 29.4V during bulk phase in constant current, and then that same voltage during absorption phase in constant voltage. Eventually the 7s group will stop accepting current during absorption, and the charger will think the pack is fully charged.
29.4V is exactly 4.2V*7, so if your pack is BMS protected, and every single lithium cell in the pack is BMS protected, it seems like it should be safe? The cells I'm using are rated as fully charged at 4.35V, so even 4.2V does allow a little bit of headroom, and the overall BMS would kick out if 29.4V is exceeded anyway.
Usually the downfall of a lead charger is the float, but even then, it's going to kick in at ~3.85V/cell, and will replenish what was consumed by the load that's attached to the pack. And if the pack has a constantly draining load, and is only charged when there's insolation, it shouldn't stay in an excited state for very long, I wouldn't think.
Thanks,
Chris
Thanks,
Chris
