Maybe, see belowCan I put two 24 volt batteries in series to have 48 volts going to the inverter but charge them separately at 24 volts?
"Similar" is extremely vague compared to posting some actual datasheet specifications of the batteries in question. We would be happy to help but most of us are not psychic. I believe the well known computer saying applies here. "garbage in, garbage out".The 24 volt batteries are similar but not exactly the same. Thank you in advance for the help.
My question is hypothetical, I believe that batteries in series if they are not identical charge at different rates which makes it a bad idea. So hypothetically if batteries were charged separately perhaps it doesn't matter if they are not identicalMaybe, see below
I have no idea why I did not see this post earlier. But thank you for the post, did you run a separate charger to each battery while they were still connected in series?Just seeing this. FWIW, I once had four 12V batteries wired in series to produce 48V. I recharged them several times per year with four 12V chargers, connected one to each battery. Never seemed to cause a problem.
I did, and it worked fine for me. I haven't had that system hooked up for about 4-5 years now, but it got us through several storms and outages. Basically, I had an old server UPS that formerly used a 48V battery. I just yanked that out and rewired it with the four marine batteries. Because I didn't have a 48V charger, but had found a great deal on four 12V chargers, I just connected one to each of the four batteries and plugged them all into a big charging strip. Worked for me.I have no idea why I did not see this post earlier. But thank you for the post, did you run a separate charger to each battery while they were still connected in series?
Thank you very much for the response.I did, and it worked fine for me. I haven't had that system hooked up for about 4-5 years now, but it got us through several storms and outages. Basically, I had an old server UPS that formerly used a 48V battery. I just yanked that out and rewired it with the four marine batteries. Because I didn't have a 48V charger, but had found a great deal on four 12V chargers, I just connected one to each of the four batteries and plugged them all into a big charging strip. Worked for me.
