This type of inverter has a small issue.
The transformer in the inverter does produce the neutral while it is running off grid. When off grid, the neutral should be ground bonded. But any time you are connected to the grid on the input, this ground bond needs to be lifted. Inverters from Schneider and Victron (and probably others as well) have a relay that connects the neutral as needed depending on the operating mode.
If this is in a camper, boat, or other mobile system with a shore power connection, you should get a transfer switch box that does the proper neutral ground bonding. Even if you only connect the L1/L2 to a 240 volt split phase shore power connection, you still need to lift the neutral to ground bond from this inverter output. Any imbalance between the L1 and L2 on either the grid side or the transformer in the inverter will cause the neutral tap of the transformer to NOT be at proper ground zero volt potential.
In my Schneider XW-Pro 6,800 watt inverter, the output transformer neutral center tap is left floating when the system is running on grid. The inverter is essentially only pushing out 240 volt floating AC current. The grid transformer is then supplying the neutral. If the system switches off grid, it disconnects the L1 and L2 inputs, and then connects the transformer center tap to the neutral buss to provide the proper 120/0/120 split phase AC output.
Since this inverter appears to lack this neutral disconnect relay, you need to be very careful how you run your ground bonding.
