Can someone please help
I have 8 500W solar panels, a 6kw Victron hybrid smart inverter and a 4kw BYD Battery and accessories. I would kike to connect the set up to a house consumer unit. The grid is so unreliable so I would like to use solar as much as possible and only use the grid when there is not enough energy from solar. I may want to use solar aided by grid if solar is not able to power all the load, maybe by having high consumption loads powered by the grid and the rest by solar. Can you please help me to wire the consumer unit. I am not sure if you can have two power sources to a consumer unit. I have ordered a second battery but it will take about 3 months t arrive in Africa. When it arrives then I wont need the grid at all. I do not need to supply power to the grid, so no grid tie.
