Couple Verification's about electrical setup for Non Grid tied (Feedback) system
I drew out a quick diagram
1) My main panel is in my house. Normal Ground/Neutral Bond Main panel
2) I have a detached garage on a 100amp Sub Panel. Ground / Neutral Seperate Ground Rods outside of building (as per code when built)
I am beginning my road to start adding Solar to detached garage loads
I plan to use a EG4 3kW Off-Grid Inverter. (one to Start, then add 2nd later in split phase)
To Start, I will not be using a battery (will add as budget allows)
30amp Breaker from Sub panel to Inverter (Ground and neutral still seperate) Black/White/Green
30 amp Breaker in Seperate Breaker panel (for inverter loads)
The Questions are:
1) Do I bring Ground back from the inverter to the Seperate Breaker Panel? and keep my ground neutral seperate
2) Grounding my panels, Where should that grounding be run to? My Grounding Rods?
The Questions are:
