Well, as luck may have it Amazon will not ship batteries to my location. Found a few sites that would but the freight charges are huge. I purchased two Duracell Ultra Platinum AGM BCI Group 31M Deep Cycle, Starting Marine & RV Battery
I want to buy two more for my 400 watt RV/portable solar generator system I am building, but want to make sure these batteries are not to much of a waste of money. I cannot use lead acid as I may have to use the batteries in living area sometimes. I do not want to use LifeP04 for several reasons. I am hoping these batteries will work for three years till I get a chance to actually arrive in the lower 48 states and can upgrade to LifeP04 type batteries.
Anyone have experiences with this particular model battery?
- Duracell Ultra Platinum AGM BCI Group 31M Deep Cycle, Starting Marine & RV Battery batteries from a local Battery Plus store.
- They have a 10% off coupon going on right now. I did not notice these batteries said "starting in the title" I was going off the specs which do not mention starting, just deep cycle.
- Item Number: SLI31DTMAGMDC
- Brand: Duracell Ultra
- Voltage: 12
- Format: BCI Group 31M
- Lead Acid Type: Deep Cycle, Starting
- Capacity: 105AH
- Cold Cranking Amps: 800
- Battery Type: Premium
- Capacity 20hr: 105AH
- Chemistry: Lead Acid
- Cranking Amps: 1000
- Lead Acid Design: AGM
- Made in the USA: True
- Maintenance Free: Yes
- Marine Cranking Amps: 1000
- Product Category: Marine/RV
- Product Sub Category: Basic AGM
- Terminal Type: DT, SAE/M8 Stud, SAE/M8 Threaded Post, WNT
- Usage: RV, Sump Pump
