Hello all!
I am in the design phase of my solar system and would love some advice from the experts (Will Prowse you listening?)
My system will not be needed for 2 more years so I am in absolutely no rush as battery technology will change over 2 years so even new on the horizon untested battery tech (IBM) is fine with me for this discussion.
I will be limited in RV roof real estate to 300 ish watts of panels (Class B RV) so that is that..
My concern is that if I bought something simple like a Goal Zero 3000 which uses NMC that I am losing out versus going DIY but I might be wrong.
Again, cost is NOT the question but rather shortest charge time 1st and charge cycles life 2nd.
Here is the question: At present and in the near future (2 years) what is the best battery technology to charge quickly and get maximum charge cycles since 300 watts of solar mixed with alternator charging will be my only input for recharging the system. Lets say a 3000 watt hours system?
Its not that I have a problem replacing individual components overtime as they fail from normal use but I am wanting to know where the cut-off is, so lets say its Battery Tech A = fastest charging and less charging cycles OR Battery Tech B = middle of the road for both OR Battery Tech C which is slower to charge but maximum charging cycles.
Since I will only have alternator charging and 300 watts solar for restoring battery capacity I assume fastest charging is king.
I will be using most of the 3000 watt hours capacity on most days. (assume 80% usage of total capacity 5 days a week)
Considering my usage, is it best to accept that there will be a need to charge via an external power source?
I can obviously drive longer and use the alternator to charge but if gas costs for driving only to charge vs finding an external power source such as a camp ground etc (perhaps twice a week) I would rather be parked if its the same costs.
I don't expect anyone to know the costs of driving a 15 mpg vehicle for charging sake compared to varying campground costs but knowing I have the fastest charging rate (the solar controller I know, I know but just Battery Tech please) with a good or even poor charging cycle life is where I need guidance from the experts.
Any bonus advice that can be offered is also greatly appreciated!
