On my RV I have 2 x 100watt panels hooked up to my PWM controller in parallel with 10 gauge wire. Then from there off to the 2 x 6v deep cycle batteries hooked up in series. I have a battery disconnect on the negative line between my battery and the trailer chassis. I also have another disconnect on the negative line between my solar panels and controller.
After finishing the install everything seem to be working in order, the batteries were at 12.6 V when I left the trailer in the evening. I left it for one full day to charge, the weather was sunny with few clouds but smoky from a forest fire. While charging I am getting an average of 88 watt @ 5.1 amps. So the trailer batteries had a whole day and part of the next morning to charge. When I went back late the following morning the voltage read 13.2 V. I have the disconnect battery switch turned off so that there's no parasitic draws other than the solar controller. When I switch the disconnect switch off between the panels and the controller obviously the controller shows no more input to the batteries. However, the battery voltage starts to drop from 13.2 V down to 12.7 within 15 minutes.
I am assuming that I'm getting somewhat of a false reading of the batteries when they're being charged by the solar panels as that voltage is being read as well. But what I am not sure about is why the battery voltage is dropping or if that's normal with deep cycle batteries?
The other thing I would like to know is if there is a way of getting a reading on the controller that is reading just the batteries and not the power coming in from the solar panels? Or is this a feature of a better controller?
