Hi all,
Long time lurker here and feel reasonably prepared to jump into finally planning and executing my own Solar Storage build in the coming months.
To set the scene I currently have a residential solar install (3.6Kw) which is grid tied on the 2015 Feed In Tarif. This is reasonably generous and nets me approx 18p/KW produced whether self consumed or not (generating approx 4000Kw per annum so cira £700).
As battery prices have come down, and as energy prices are rising I have decided that the pay back period is sufficiently attractive that it is worth acting now. Additionally, as I look to install whole house aircon and have just taken order of a new electric car, a suitably sized battery storage should reap serious benefits over it's lifetime. I am also now on the Octopus Energy Go Tarriff which allows me to draw electricity at 5p/KW between 0030 - 0430hrs each night.
Currently I have an offer of 17.4KwH of storage, installed, for a very reasonable £5495 however this, coupled with a planned £7500 for whole house AC, seems relatively simple to beat with a DIY system.
My plan is as follows:
16s3p bank utilising 48x 200ah cells to give me a 30.72kwh bank at 48v. This would link to an independent battery charger/inverter to compliment my Solax X1 boost solar inverter.
As my daily usage is approx 15kwh and I would expect this to increase to approx 25 (only occassionally) due to aircon (heating or cooling on hottest/coolest days of the year) I figured 30kwh of cells, compressed (for extended life) and generally kept between 30-80% charge would enable me to be entirely self sufficient (15kwh available) during peak energy cost hours, charge during solar generating weather windows, and top up only a small amount at night. This would save me easily £600 per year.
Now a few questions as I should mention that I am an amateur at best (although I am experienced/familiar with household electrics and the safety principles associated with this sort of thing),
Batteries - where is the best place to get them. I have discussed options with Amy Wan on Alibaba however she is offering 280 or 304ah cells which put things out of my price range. I have found some very cheap cells $40 for guaranteed 175 - 195ah capacity. I could oversize the system further if these were any good (beyond the average capacity). https://www.aliexpress.com/item/100...e-5&pdp_ext_f={"sku_id":"12000024300481546"}/
BMS - with the described configuration of cells, what would the best BMS configuration be to allow control/monitoring of each cell? How many BMS would I need? Note that I would want to be able to draw 60amp sustained load. Charging would be 60amps as it would need to share the replen window with my 7.4kw car charger. Also note I would not have the car charger on the same circuit as I would want this to run independent of the battery.
Charge Controller/Hybrid Inverter - what options should I consider. For the 60amp output (14.4kw) to the main house circuit what is the best choice?
I thank you in advance for your comments. If i'm barking up the wrong tree then please feel free to correct me/advise otherwise. I will not be moving forward on this until I have settled on design of the system so your advice is key.
Stew
Stew
