Australia18,720Wh available in the bank, 21 panels, but you dont say the wattage.
What specs are on the panels?
How much did the batteries cost?
How long did they last?
What area of earth are you in?
Why are you changing to lithium?
I'm just adding LFP in to become Power Pack #1 as my FLA bank has decided that retirement is in it's future but will be used till retirement as secondary power....
Both the solar controller & inverter will have to be reprogrammed for an LFP profile, there is no equalization or float requirement and voltages have to be right, not too much and not too little.
to replace your 48v/720AH gross FLA (3 banks of 8 in series @ 240AH per series) is roughly 360AHrs net @ 50% DOD. Your looking for a 48v/400AH which leaves a bit of room at the top & bottom for margin as you ever want to discharge 100% or hit 100% full charge, it's best to lave 10% on either end. The advantage is you can use 80% comfortably from an LFP and charge it faster than FLA.
A better description of your batteries & equipment will help you get a better response, above if rough guestimate based on the minimal info provided.
Given that your in the states, I would jump all over the BYD and SamSung ESS deals which are available right now (several threads ongoing atm) which are an incredible deal if your up for a bit of DIY. IF you want to buy brand-new I would look at the current Sinopoly & Calb and BLS offerings which will has just covered with a good BMS. If budget is good, there are Power Walls but for example, Tesla ones have to have their installer and such but there are others out there too.What 48v 400ah lithium would u look at purchasing? That's so much for your help. I uploaded some photos
So that I understand with the video u uploaded would I need 16 of them to have 400ah???Given that your in the states, I would jump all over the BYD and SamSung ESS deals which are available right now (several threads ongoing atm) which are an incredible deal if your up for a bit of DIY. IF you want to buy brand-new I would look at the current Sinopoly & Calb and BLS offerings which will has just covered with a good BMS. If budget is good, there are Power Walls but for example, Tesla ones have to have their installer and such but there are others out there too.
A recommendation depends on your budget, willingness / capability for DIY, expectations like warranty etc... Case in point, I thought I would be smart and bought a "ShunBin" 24v/400AH premade pack which I thought was a good deal, not so much, I screwed up and in hindsight, it would have come out to about the same money, had I bought matched cells and the BMS etc and put the pack together myself (and it would be up NOW rather than waiting on parts)
Have a look at this video here:
IM in Australia, just confirming I will Need 48v 400ah of lithium batteries is that correct?Given that your in the states, I would jump all over the BYD and SamSung ESS deals which are available right now (several threads ongoing atm) which are an incredible deal if your up for a bit of DIY. IF you want to buy brand-new I would look at the current Sinopoly & Calb and BLS offerings which will has just covered with a good BMS. If budget is good, there are Power Walls but for example, Tesla ones have to have their installer and such but there are others out there too.
Would 2 of these workGiven that your in the states, I would jump all over the BYD and SamSung ESS deals which are available right now (several threads ongoing atm) which are an incredible deal if your up for a bit of DIY. IF you want to buy brand-new I would look at the current Sinopoly & Calb and BLS offerings which will has just covered with a good BMS. If budget is good, there are Power Walls but for example, Tesla ones have to have their installer and such but there are others out there too.
