I am looking to upgrade my RV rooftop solar system from 200 W to 400 W. I presently have two Renogy 100 W panels on the back half of the trailer, wired in series to reduce line losses as much as possible. The Renogy panels are 1.5 years old. Their listed specs are Vmp=18.6V, Imp= 5.38 A, Voc=22.3 V, and Isc= 5.86 A.
I am adding two new HQST 100 W panels to the front half of the trailer. These panels’ specs are Vmp= 20.3 V, Imp= 4.93 A, Voc=24.3 V, and Isc= 5.34 A. My plan is to create two parallel strings of two panels in series. Because it will be difficult to relocate the two existing panels on the roof (taped on), and because of the way the roof is typically partially shaded at a campsite, it would be best if each two panel series consisted of one Renogy and one HQST. Are these two panels close enough in spec and age for this series string to operate efficiently? Alternatively, I could series pair the two Renogys together and the two HQSTs together, but because they would be on either side (port and starboard) of the trailer each panel in the series might not get full sun.
Any thoughts from the group on best way to go?
Second question:
Based on Will’s reviews, I really like the EG4 LL Server Rack 400 AH battery. However, this setup is for a boondocked RV in remote areas, and I really need to try to build in as much redundancy as possible so I am not SOL if something goes wrong. As a result, I am most likely going to go with two 200 AH RoyPow Power Urus batteries. This gives me two BMS’s and at least 200 AH should a battery go bad.
Any thoughts on how batteries fail? I mean it may not be any more reliable to have a two battery system if the way things typically fail is that some other part of the system takes out both batteries at once. How reliable are BMS’s and individual batteries these days?
Third (and last) question:
I fully understand low temp charging protection and possibly battery heaters. What about low temp discharging? Would consuming power from a charged battery at below freezing temperatures cause damage? How about simply a charged battery sitting in a below freezing condition? I am planning on my battery compartment being within the living space of my RV, but it would be possible for the entire RV to go cold.
Thanks in advance for any and all assistance.
BTW, I love Will’s site and videos. As another poster noted, “I wish I was excited about ANYTHING in life as Will is about batteries”! He’s been a real help. I was particularly impressed by the fire he started with the punctured Chins solid state cell. What would happen with a LiFePO4 chemistry, say if you punctured it or shot a bullet through it?
Second question:
