I was not sure where best to post this so used general discussion. If it is best elsewhere please advise and I will move it.
I am ordering a new Inverter/converter for my Motorhome with plans to later this year replace my lead acid batteries with LFP. Currently I have a Xantrex Freedom 485-25 (2500 watt) unit that is modified sine and 4 golf cart batteries in 2S2P for 12v output. Initial advise was to upgrade to a 3000 watt I?C like the Xantrex SW 3012. In doing so I am learining that this will also require upgrading AC output wiring from 12ga to 10 ga or putting in line breakers to limit output to 20 amp. Other that the occational use of high wattage appliances such as the microwave, coffee maker, hair dryer, induction range or space heater when boon docking, I do not see any use with a draw over 2000 watts. Perhaps running the induction range (1 burner) and coffee machine at the same time could exceed that. We do not dry camp a lot and do have access to LP when we do so that can of course that can take off some of the strain. The only other big A/C draws are electronics like a computer or TV. THise items likely draw less than 1000 watts combined. There is not a huge difference between a 2k and 3K I/C ( a couple hundred bucks) but am I making a mistake to go to the larger unit with greater watt usage when idle and the extra cost of rewiring etc.?
