Shahid, you said this is a FARM correct ? If that is the case, you can't go without water for long and from the description of your climate zone, it isn't an option at all. I know what +50C feels like, as well as -50C , many don't, either is extreme.
Quick recap.
- You want to run primarily off solar for your water pumping and your home use.
- You have access to Grid Power but only wish to use it as a failsafe backup to charge batteries IF needed but not to feed the grid.
- I will assume you are using 220/230 VAC @ 50Hz (NOT 240VAC Split Phase @ 60Hz (North American form))
- You have solar @ your well. The Well is located 50 metres (164' for the metric challenged) from the home.
- You are willing to increase the solar on current site or on your home as well.
A few practicality issues & points to consider.
- Running DC lines for 50 metres + is very costly in copper so generally impractical to do, also presents other challenges.
- Running AC is considerably cheaper & easier to accomplish,
- All in One systems are appealing BUT they have certain quirks and potentials for unpleasantness. Consider if the SCC (Solar Charge Controller) of the unit fails, the whole unit must be taken down for repair (if repairable) meanwhile you are not generating & using. Same if the Inverter or Charger components fail. Components can and do fail, usually at the worst possible time as well.
- "Stackable" components like Solar Charge Controllers, Inverter/Chargers are readily available and can offer a certain degree of fault tolerance when assembled properly. For example one SCC could fail but the rest take up the slack & keep running, while bypassing the failed one.
- Inverters are available which can use the Grid as backup and can be programmed for various thresholds. Some use internal ATS (Auto Transfer Switching) while others use an external ATS. Many also have a similar AGS (automatic Genset Start) feature to startup a backup generator system, most often requiring an external unit for that control. (Propane fuelled gensets are better in most cases because the fuel will not sour if stored for periods of time, they do have quirks in cold but that's not on of your problems).
- Intermixing of different "gear" can be problematic when it comes to managing & monitoring the system for performance & fault control. It is generally quite prudent to stick with one common family of products.
Some options to consider.
- Are you willing to build a "powerhouse" where your solar system is located ?
This can house the solar equipment including the batteries all in one spot, from which you can run AC to your home using appropriate wiring BUT it places your gridline access further away, adding some cost to run a line to that building. This also resolves the distance run as AC is easier than DC.
- Would you consider a "dual" system, one for the house, one for the well system ?
Both could theoretically run independently yet be capable of backing the other up so if one system fails you can run AC in reverse <-> between power house & home. Of course the GridLine would go to home first then feed to powerhouse (easier) and serve both as needed. It is possible the Powerhouse may need grid charging occasionally and the home one may never need it, or vice versa. This "assumes" both would have charging capability as mentioned above.
- Depending on how "critical" you determine your system(s) to be, are you willing to go with 1st Tier product or would you be happy with 2nd tier or "Value" stuff ? Value stuff being the cheapest imports and not the most reliable or configurable & usually without any form of management / monitoring capability. 1st Tier is Victron, Outback and so on. ( NB, I don't use Victron, as it wasn't available here when I started, but that is seriously NICE gear and you do get what you pay for, even at the premium that it is)
If I was building my system today, it would be Victron.
- SUPPORT ! noone mentions that, oddly enough.
If you import a value piece and need support, good luck. Do you have local vendors who will support your purchases (if you DIY) or are you going to buy everything off the web and diy it all yourself & hope for the best ? This is important, especially for a critical situation.
Q: How long before the livestock is affected without water, what about crops ? THAT is the maximum time you can be down ! If the SCC or Inverter fails, you do NOT want o be waiting on replacement / repaired parts, you'll want to run to a shop & get it fixed / replaced ASAP. Please consider that.
I hope that helps you consider more aspects and issues before you get too deep into your project. Everything you want to do is most certainly possible but a good solid baseline plan is important and knowing what can go wrong is essential to plan for ways to reduce any risks from failures or … Please consider the various issues & aspects.
A small point to ponder upon. A fellow not far from here who runs a horse ranch, DIY'ed a solar system using "very" value equipment (no safety certified gear, no CSA/UL/ETL, nothing, off grid, so not inspected) and it ran fine for 6 months. 3 days before Christmas the main horse barn burnt due to a failure in the equipment, 23 horses (show horses to boot) were lost and only 2 firefighters injured. NO INSURANCE ! The fool had everything in the main barn, several of us told him not to for just that reason and knowing he was bodging it up but he knew better than everyone else.... Now he is on the hook for all of it and is broke and will loose the ranch as a result of his "brilliance". This is not something I want to see happen to anyone, ever.
