as a result - returned to the old firmware - 6.17
The question remains - can the inverter mix panels and mains
Hello. ISOLAR-SMX-II-5.6KP. I installed the 6.35 mixload software. Parallel options plus or 10 menus disappeared. Wifi does not connect either. Works without a battery. Mix the network with pv.Hello. I run the GModusbus and this is the result.View attachment 135433
I want to mix AC with PV if possible. If not I think i am going to sell the inverter.
After reinstall wifi datalogger and 2 reboot inverter works wifi. ThxHello)
I have 6.35 Worked with WiFi.
You may need to reload the logger. I'm currently txting firmware 63.3
Hello. In the topic. As described in the second post. Sleeper85 .(wifi unplug)Hello. Can you tell me how you did the sofware update? What program did you used, what are the steps? Thank you.
Hello there! Could you please inform me if the battery is continuously charging or discharging on version 3.17? I suspect this is occurring because, for some unknown reason, the inverter remains powered by the battery even when connected to utilities. I'm very interested in purchasing this model, but this is the only issue holding me back. If there's a way to prevent the inverter from discharging the battery during bypass, that would be truly amazing!Hello)
Hi,Hello. I will share my experience with SMX-II-5.6KW firmware. I tried all three firmware.
6.35,63.3 and 6.17
6.35 - kills the battery,
63.3 is a more gentle mode, but still a constant charge discharge.
With a load of 2 kW from the panels, there was a kilowatt and 1 kW from the network. and 12a from batteries. measured with current clamps at the input and output.
Hi,
I have firmware 6.35, could you share the other 2 versions?
Thanks
Thanks for reply!6.17 version
ISOLAR-SMX-II-5.6KW dead after firmware update
It was finally the EASUN POWER EU VAT-FREE Store where I ordered my unit which responded to my request and sent me the requested firmware, without battery (mixload) 6.35 version (which I do not recommend to use) and the regular firmware with battery 6.17 version which works well for me...diysolarforum.com
Sorry, I don't know.Thanks for reply!
I remember that original version of firmware was 2.08.
Do you know if there are difference between 6.17 and 2.08 ?
My inverter is Easun SMX II 5,6KP the firmware 6.17 is suitable for both KW and KP version of inverter?
Ciao !!
No problem, thanks.Sorry, I don't know.
Cześć! Kupiłem SMX II 5,6 KW i dokonałem aktualizacji bez baterii. Nie trzeba dodawać, że falownik jest martwy. Brak wyświetlacza, tylko czerwona dioda LED na płycie sterującej. Po kablu USB widzę podłączony port COM w menedżerze urządzeń (CH410), ale dalsza komunikacja nie jest możliwa. Czy komuś udało się przywrócić pracę tego falownika po takiej sytuacji? Czy jest gdzieś schemat płytki sterującej? Widzę, że to SRNE HFP4850S80. Płyta sterująca DSP była w wersji 2.0.8, jak wynika z etykiety naklejonej na chipie DSP, ale nie mogłem znaleźć żadnych innych szczegółów w Internecie.
Każda informacja jest bardzo cenna.
Dzięki!
