ameyaonline
Hi everyone, I have an EG4 6000EX setup, 3 parallel inverters, 30kwh battery bank powering a completely off grid home (no utility power), just replaced the previous setup this summer with old inverters/AGM. I have Kohler 12RES Propane generator out hooked into the utility in of the inverters so I can manually start the generator when I need to charge the batteries and power the home at the same time. The previous setup was designed to automatically start the generator based on a parameters: incoming load, battery voltage. I want to do the same, well at least based on battery voltage. The Kohler 12RES has 2 control wires coming out of it from previous setup that went into the previous setup. Anyone has experience with this form of a setup or an AGS module I can hookup and program to auto-trigger generator? This is an critical step for Upstate NY winter months :-( Thanks in advance for your help and time.
