Some information found on searching...
Good discussion as well:
I can't really live well with Flickering LED Lights, even if we are talking about 2 to 3khz dimming frequency. Which LED Lights did you test out that actuall...
ledstrain.org
They cite using a bulb which better decouple the AC from the DC, a DC-DC converter built-in (after the AC-to-DC conversion), something to that effect. I installed a bunch of Hyperlite high-bay LED dimmables for my shop and even the outside side-wall building lights of same brand, also dimmable.
They have a separate 2-wire dimmer circuit on them (0-10v range), and they are truly flicker-free at any brightness as far as I can perceive.
I also have some of the smart bulbs which the dimming is not controlled on the light switch via AC input to the bulb, but rather in the phone app, where I assume that the dimming is done directly on the low voltage side.
I don't know if this all plays into the OP's issue here, but generally I find it just depends on the bulb being used, since there are different methods used to build an LED driver, some better than others, and whether or not they are dimmable or non-dimmable (based on the AC 120v side, or DC dimmable).
I'd just say, buy a bunch of test brands / models of bulb, and find one that doesn't flicker with your inverter, then buy more volume of those type. Plenty of people here don't have flicker problems with SolArks though for sure..
