I have some 18650 batteries. Some are about 10 years old, and some are brand new. I have a tester that will test batteries at a chosen amp draw, and will stop the test when the voltage reaches a set point. The old batteries are rated at 3100 mAh, starting at 4.2v, cut off at 2.5 volt, 0.2A draw (according to spec sheet).
My question is re the cutoff voltage. If I run a 1 Amp load test, and set the voltage cutoff at 2.6v, then it does cut off at 2.6v, but then floats back up to about 3.15v fairly quickly. So I assume that the cutoff voltage, is always under load?
I only want to get a baseline for the batteries, particularly the new ones, so that I can closely match the cells, as they will be used in packs of 4. Some are going in a torch that is a very high draw, and some are going into a power supply for an esp32 device, that only turns on every 6 hours, so is a very very low draw. I just chose a 1 Amp draw as a nice round number, and a somewhat quick test, unlike the 0.2A draw that would take over 14 hours.
If there are any good links to details on battery testing like this, I would be interested to know about them.
Thank you
David
Thank you
David
