Solarfun4jim
Solar seduced :-)
Questions...
1/Looking at the above setup, any reason why i couldn't use thick copper plates to simultaneously make the 2P & Series connections?
2/Understanding that heat rises, if i insulate around each cell with kingspan 25mm, this provides rigidity within the confines of a casement, plus insulates in cold weather. If i connected a heat pad under a glass plate below the whole battery bank(for cold protection when needed) and connected a fan system for the air void above the terminals such that the thick copper connection plates would act as heat sinks and thus provide me the over temp heat dissapation when temp climbes above 10degC. Any downsides to insulation around the sides....bearing in mind i would generally only be discharging at 0.2C and never as much as 1C rates...so minimal heat generation??? I'm also assuming, that if any cell developed a 'heat spot', that the BMS would likely kick in to protect?
I'm looking to build a motorhome system, such that after 16 years of use, will still have a reasonable capacity to then reuse for my current grid tied home system, which at that point will no longer get feed in tariff monies...so long term dual purpose.
Any opinions on the thick copper connector plates or insulation proposals?
