First, Thanks.!! I have learned a great deal from your Youtube videos. Batteries.?? Currently 2 HUGE flooded-lead-acid "Bus" batteries. I am currently living only on Retirement income, so when I save enough money I will be going with Lithium-iron-phosphate. Yes, the entire building is 'shaded'. I only get 1-hour of un-shaded Sun light per day at best, but it still keeps the batteries Full. In direct sunlight, the (5) 150-watt panels put out 21+volts DC. The Watts and Amps keep changing on me, and my current MPPT controller does not keep records. Bummer.Looks great!! Shed based systems rock. What type of batteries are you using? Looks like your roof is shaded in your profile picture. On a ideal day, how much power can you produce? And thanks!
"Motorcycle"... It has a single 12vdc wire running to my Motorcycle battery. It just keeps it topped-off. I switch it OFF before disconnecting the Anderson Connector under the MC seat. Should I change the Switch..?? That circuit is also FUSED from the small Fuse panel. In the picture the Switch is Off, but the Light is still ON... reminding me that the circuit is still connected to the Motorcycle.
Personally, I think it looks a little "cluttered", but then I used to restore Show Cars for a friend. I will check the 'pull disconnect' soon... probably this evening. Attached is a pic of the starting point with only 2 panels and NO fuses (other than the Pull-panel)...Watching your video, I notice you also have a pull disconnect for the solar. I use those type disconnects A LOT, and the pulls have various qualities. Next time you pull the handle, check if the buss tabs on the pull are riveted in, or just plastic clips, also check if they are aluminum plated with copper, or if they are solid copper, or even tin plated copper.
I’ve had a lot of broken pulls. Aligning the pull in the disconnect is annoying, and difficult at times.
Everything looks nicely laid out.
