OzSolar
Whatever you did, that's what you planned.
2v cell from a 23 yr old 48v FLA battery still alive in the wild. Doing well actually.
Last May (~8 months ago) I found this cell way under spec compared to his 23 counterparts. Pulled it, then wired around it, reprogrammed my inverter. Left alone until a few weeks ago. SG read was just over 1 and Voc was around 1.5. Mucho bad, right? Fool's errand to follow but as the king of fools why not??
So I started with dumping out the acid, rinsing it out with my well water ~6 times. I'd jiggle it around assuming I was knocking the bad stuff loose.
Then I added 40 grams of EDTA for ~24hrs. During that time I would try to shake it a little bit by rocking it back and forth. Dumped that out, rinsed a few more times, then put fresh battery acid back in, 1.5 gallons is what it this cell needs. Yeah it’s a beast, have to use a forklift to move it around.
Charged it back up and to my complete disbelief the SG has returned to 1290. Now I’ve dead shorted the battery with a random roll of #8 wire I had laying around, somewhere between 50' and 100' (Refer to the title of this post). It’s holding a 35 amp load @2.1 volts. Guess I’ll put back into service and waste a lot more time getting the others rebuilt.
