A Battery Management System is just that, a management system. The BMS is simply a switch that is either ON, under normal conditions, or OFF, if out of range conditions of Current, Voltage or Temperature are detected. When OFF the BMS protects the cells from irreversible damage. The BMS has no ability to rectify AC to DC or regulate charging.
If you wish to charge a battery you will need a charging device such as a stand alone charger that plugs into a power outlet or a solar charge controller or an inverter-charger.
